Muso QB 1st Gen does not go into standby
Hi everybody,
when using the Muso QB in MultiRoom (receiving signal from Naim Uniti 2) it quite often (not in 100% of all cases but close) that after stopping the stream it does not go into standby. I.e. the white ring stays on forever.
Furthermore, restarting the stream/Multiroom is also in most cases not working, i.e. I have to deselect and select the Muso QB at least once to get it playing.
Does anybody of you faces a similar problem, and, if so, how to get it working?
Kilian
Edit: Restarting router, disconnect Muso QB from power (as well as the Naim Uniti 2) does not help.
