Hello Naim Community.
I have a problem connecting my first gen Muso Qb to the network after upgrading to a Google Nest WiFi mesh router with a second point. I can see this issue has cropped up several times over the last few months. I have followed the advice, but to no avail. I am hoping that the posts that have petered out have some other options that worked!
My Muso has happily worked on my wifi with my NDX for a few years. I upgraded my virgin hub to a google mesh router plus point. The wifi works fantastically, everything connects as before, except the Muso. I have tried every combination of factory reset, rebooting the router (and modem), the muso etc. I’ve tried to connect via an ipad, a mac, an android phone and 192.168.1.12.
Mostly I get an error message, via airplay, of ‘unexpected error’. But if i disconnect the second point, I can connect to the wifi. But the connection is lost when the muso ‘goes to sleep’. And I have to start again. I need the second point for my home wifi, so its not an option to have that permanently disabled. Of course, I can use bluetooth, but that means i can’t use it with my NDX as a home system.
The muso has v1.8 firmware.
Grateful for any help!
