This is still a problem as I just attempted to update the firmware from 1.8 to 2.0.
I understand a smartphone is complex, but I didn’t think it would be so complicated to update firmware on a dedicated audio device.
Power cycling, Ethernet connecting it to the Wi-Fi base station, and pressing the reset button for 6, 10 or more seconds will not move it out of the solid red indicator being on. It’s a brick now.
Mine, 2nd generation, also froze during update. After testing everything, and after been checked by two service shops, I got a brand new one.
May certain settings initiate this ? Should we reset to factory setting before updating as normal for some other equipments ? The new one came directly from factory and updated without problems.
Please bear in mind that Naim are currently dealing with a backlog of email enquiries. They’re getting through them as best they can but there can be a bit of a wait before they’re able to respond properly, so your patience is appreciated.
Well, Naim tech support and I gave it several tries including redownloading the firmware update and writing it into the unit, but no dice. The solid red indicator persists, so I have offered to send the unit to them to troubleshoot if they are able to, else it’s going into the garbage bin.
I solved the same issue by doing the following:
1: Turn off the Muso (from the wall plug).
2: Press AND HOLD the reset button on the side - KEEP pressing while plugging the Muso back in.
(This will sidestep the Muso automatically going into the firmware upgrade cycle when simply turning back on).
3: Now release the reset button.
The Muso will then go into all sorts of gyrations but eventually will resolve.
