I bought a Muso Qb 2 for listening to music while I work. I audiotioned the speaker in another room with plenty of space around and I loved it. However when I moved it to my desk sound wasn’t the same.
I know that this is not a desktop speaker, but I would like to know if any of you is using it for near listening and where do you place it. I was thinking about puting shelf above my monitors and try that way.
I don’t want to return it because I’m aware of the potential of this little speaker, but I don’t know where to put it.
I have them on glass, and not stuck to the muso base by their self adhesive pads as i take it on holiday with me. If it were wood they were on i would just cut a few pieces of grease proof paper to stick under the pads, you would not see the paper.
Have a play with the settings and see if that helps. For nearfield listening I would guess that you might prefer to turn loudness off, and set the room compensation to either near wall or near corner.
