Muso QB placement
Just bought a Muso QB for my study. Floor space is limited but wondered if it would sound ok if it was on a shelf in my fitted bookcase. It would be by itself on the shelf. I know it’s not ideal but would it be ok?
My Mu-so Qb 2 lives in a bookcase and sounds sublime. Since I took this photo the gaps between the side of the Muso and bookcase have been filled with more books and it still sounds great.
That’s great news! Many thanks
Just make sure to adjust the settings for close to wall, and you’ll probably want to turn off the loudness. We have three Qbs, one on the desk in our study, one on the kitchen worktop, and one on the piano in the dining room. They all work well. The Qb is lovely, such a shame it’s discontinued.
Given that you say you have alreadybought it, and given that it is small and easily moved, surely the simplest thing to do is just try it in whatever positions it might fit and see what suits you best.
Thanks for the reminder about the settings adjustments.
've had a Muso (not a QB) in the kitchen for years now but in an open space so I’ve not had to worry about the settings too much. This will be my first QB so I wondered about the placement so I appreciate your advice.
I have bought one but not received it yet. The bookcase seems to be the best place for it so I just wanted to check in advance and HH has provided some good advice. Obviously, when it arrives I will try alternative positions to see where is best.
…but we, the omniscient Naimites, provide the tried and tested experience which gives the OP peace of mind and a short cut to audio nirvana, or Valhalla for eternal stereo sublimity.
Indeed, although I’ve just bought a full size Muso and that’s even better!
