Hello. Is it possible to connect a QB with the Naim app without a WiFi connection using an iPhone X? If so, please help! Thanks! F.
With the original QB, you should be able to connect with the Apple USB cable through the QB USB port.
Thanks. Would I need an internet or WiFi connection?
No, with the original Mu-Sos you can connect locally without any need for Wifi. Only thing you must have wifi for is to set-up for wall distance and loudness etc… as these are done via the App.
Or I presume also connect via Bluetooth…
