Hi Dan,
I too like the idea of less boxes and less cables. Recently I even went to listen to the Linn 360 active loudspeakers - but they were no match for my Magico’s.
FYI, when I was choosing my loudspeakers (in 2019) I heard - and was certain I wanted to buy - Focal Sopra 2s.
This assessment was undertaken in competition with many other brands, including ATC and other excellent ‘high end’ British marques. Unfortunately, my dealer then played me a system with Magico’s. The cabinets of Magico’s are practically silent (unlike many loudspeakers with a few notable exceptions) and I think this contributes to their excellence. My Magico loudspeakers are also infinite baffle designs which create some significant issues for the designer(s) - but if those issues are mitigated/solved one ends up with a really excellent loudspeaker.
Actually, I think I would quite appreciate your setup. Afterall, we both understand the benefit of acoustic treatments and use GIK Acoustics brand products.
For future, I am hoping that Magico might do an active loudspeaker - much like Focal/Naim have with the Diva. Perhaps the next thing after the Diva is what would persuade you to consider changing from Sopra 2s? There would be no visible ‘boxes’ other than your LP12, your RELs (and all the GIK Acoustics products) - all controlled from the ‘smart’ devices that we all seem to need to possess to control HiFi these days?
If I was in the market now for loudspeakers the Focal/Naim Diva product is one that would interest me (particularly if it were an Infinite Baffle design). Nevertheless, it is a strange beast:- the external felt covering is there for additional damping on the cabinet (I think) - and perhaps the felt is on the outside to overcome the space constraints, assembly cost or even fire risk if placed on the preferable interior cabinet surface with the Naim designed power amplifier.
I think Focal marketing have endeavoured to turn the above aspect into a ‘feature’…
Unfortunately, when asked, 8 out of 10 cats said their owners preferred that they didn’t climb the Diva - desirable though that really is!
This is often the way with NEW product concepts, the first one is where the designer/manufacturer sorts out all the teething issues, including some market reluctance to the ‘new’ product. The second attempt is where it really hits the spot…
I predict the next active high end loudspeaker from Foca/Naim will be one that you and I may REALLY like. Lightweight electronics to keep logistics costs low on distribution so using a switched Mode power supply, appropriate class of amplifier design for each driver set, DSP crossover and Room Correction included (ADAPT+) maybe we can get our lounges back and get rid of the GIK stuff, and just maybe the felt damping can be back on the inside… and the potential market reluctance of the cat owners on here will be solved at a stroke…
