I’ve powered down my system for 5 mins then switched it on again but still no joy. I’ve also shut down and restarted the Naim app. Should I use ‘add a new device’ or is there something else I can try?
Add the router and switch if you have one to the off and on again list.
Rebooting the router has done the trick - thanks for your help.
