Hey all,
I’ve got a pair of n-cents that have long since lost their grills.
And I’ve unfortunately recently had to share my house with a cat who loves to assault driver cones (as a cheap pair test speakers unfortunately discovered).
Anyways I’m wondering if there are any ways of acquiring some original n-cent grills or if possible some measurements for the inserts that would help me to 3D print some to protect these beauties from a vengeful feline.
I’m also open to any anti cat methods for protecting ones hi-fi
You could have your dealer ask Naim whether they still have any spares. Better, ask whether they have the metal grilles that were used on the Piano Black/Silver n-Cent.
@Richard.Dane I thank you for your assistance. But unfortunately I didn’t acquire these through a dealer and it appears Naim may not have what I need. Where should I go from there?
If Naim don’t have any then it’s a case of ringing around dealers to see whether they have a spare set tucked away, or else keeping a search saved on places like eBay so you get an alert when a pair crops up.
Alternatively if you’re creative, you could make something. Perhaps someone who owns an n-Cent could measure the grilles for you and post on here?
Maybe the cat simply has a discerning ear, and objected to the sound of the cheap speakers….
Yeah, if anyone has the grill inserts, that would be much appreciated as I have access to a 3D printer so I could perhaps print my own grills and with your permission share the files with others, as I believe n-sats etc have the same insert?
