Hi,
I like to use my N-DAC with this pre-amp, should the Signal Ground switch be set to Chassis or Floating?
Many thanks
S
Hi,
Many thanks
S
It may well not matter with the Bryston, however, your best guide is to try both ways and go with whichever sounds best. If they sound identical then go with whichever gives you the least noise or least issue with other sources. Other than that, stick with chassis as that’s the default setting.
Thanks so much for prompt response, much appreciated…
