ND5 XS. I have MinimServer running on my MacMini. When I hit ‘pc’ on the remote, the ND5 sees the MinimServer and I can navigate my library via the front screen. It works, but it’s a bit of a faff… In the n-Serve app, when I hit ‘Connect’, I get ‘Discovering…’, then ‘No servers found’. Isn’t this where MinimServer should show up? Mac mini, iPhone and ND5 are all on the same network…
Nserve is the wrong app. It only works with Unitiserve, HDX and NS0* servers. You want the other Naim app…
You need this app
Thanks, Robert – all sorted, vow…
