rob-z
#1
I like to control my NDX/SN2 threw my iMac.
Now i only can controle my set with the Naim app. Works fine.
But when i’m behind the iMac i would control my music/volume without using my iPhone.
Wil it be possible?
Will the coming an app for desktop (on the iMac for example??)
For now i was installing the N-serve app on my iMac en connecting to the music on my home server (synology) Will that be possible?
I’m giving the location in the N-serve app but it’s gone look on Google.
So can i use the N-serve app on my iMac and control my server + NDX/SN2 for playing music and radio?
ChrisSU
#2
N-Serve was only for the old Naim servers, Unitiserve and HDX. You can’t use it with non-Naim servers.
rob-z
#3
Bad
Will there come a naim app for desktop? (like controlling Spotify for example)
Klout10
#4
Hi Rob, never heard of any plans in that direction. I doubt we will see something like this - your request is understandable however.
Blythe
#5
I’d like to be able to do this too.
Sadly, not currently possible
ChrisSU
#6
If you really want to do this, something like an Android emulator might work. Or go all the way, and use Roon.
Blythe
#7
It would be nice if Naim simply made a DTC available
Blythe
#8
Or if Apple made IOS and OS compatible with each other…
I wouldn’t hold your breath!
system
closed
#10
