NA523/1 identification needed
Hello,
can someone identify which phono boards are these? S, K, E or R? Looks like S but I’m not sure…If they are S are they ok with medium compliance 15 um/mN mc cartridges like ortofon quintet series? Or should i look for NA523E boards?
System is : Nac 102 & 82 /Nap 180
Linn Sondek LP12 with akito tonearm (serviced with new circus bearings, valhalla power supply and new linn motor)
They are NA523S boards for low output MCs.
Thanks for an answer Richard. So, they will not work well with 15 um/mN mc cartridges? Better to go with NA523E?
It depends on the output voltage of the cartridge. With which cartridge are you wanting to partner the boards?
Ortofon quintet red
I see Ortofon quote an output of 0.5mV so ideal for the NA523S boards
Thank you very much Richard. That was very helpfull!
