Hi all,
First post so be gentle! I’ve just purchased a used nac202,nap200 ,napsc & stageline to go with proac studio 125 speakers. I’ve managed to get it all set up ok but I can’t get sound out of aux cd via rca. I’ve tried various rca cables but can’t get sound out. I’ve ordered a din to rca lead now hoping this will sort the problem but am I doing something wrong??? Source is a bluesound vault but also tried an old cd but nothing via rca. Do you think the rca socket is broken? Or should I just wait until the din to rca cable comes & hope it works that way? Thanks for the help in advance & sorry for the rambling
Section 10.2 in the Pre Amp Manual should sort you out.
10.2 NAC 282 and NAC 202
Input Socket Assignment
The input selection buttons select the source input signal to be
routed to the power amplifier and the loudspeakers.
The NAC 282 and NAC 202 have six DIN input sockets and
two alternative pairs of RCA Phono sockets. The RCA Phono
sockets can be assigned individually to the cd and aux 2 input
buttons in place of the DIN sockets.
Input assignment setup is accessed through preamplifier
program mode. To switch into (or exit from) program mode
press and hold the prog key on the remote handset (with the
handset in preamplifier mode). Program mode is indicated by a
flashing indicator on the front panel volume control and, on the
NAC 282, the record selection button indicators extinguishing.
Note: If no function is operated within five minutes of entering
program mode the preamplifier will return to normal mode
automatically.
Once in program mode press and hold the remote handset
1 key to select or de-select the RCA Phono socket input for
cd, and the remote handset 6 key to select or de-select the
RCA Phono socket input for aux 2. The corresponding front
panel input buttons can similarly be used to select or de-select
the RCA Phono socket inputs. The appropriate input button
indicator will flash three times on selection of the RCA Phono
option and once on selection of the DIN option.
To exit from program mode press and hold the prog key on the
handset until the record select indicators are restored and the
volume indicator stops flashing.
Thank you so much!!! If I’ve got a din to rca cable coming from flashback do I need to alter anything as I may as well wait until it turns up! I’ve got my turntable for music anyway.
This amp really makes my proacs sing, I am over the moon with my lockdown blind buy! Also got a hicap2 coming next Friday so that should help even more from what I’ve heard.
Yes, I wouldn’t bother if you have the RCA/DIN on the way. That should sound marginally better anyway. Enjoy
