When I listened to a 272 at my dealers some time ago I asked him to suggest some alternatives. One was NDX/Supernait 2, which I found slightly better than 272/250. Next up was NDX/202/200DR, which I found to be a significant step up. Adding an XPSDR to the 272/250 made it a closer match, although I still preferred the NDX/202. Not that any of these systems sounded bad, it’s all relative.
I looked at a 202/200 when I still had my 72/HC/250 and wasn’t impressed. I’ve never got on with the 202 or 200 for that matter. With the 202 being a pretty big step down for me. I’d get a 250DR for your 272 before messing with a 202.
I would hold off and get the 282. Go for the 250DR and keep the 272 in the meantime. Try the XPS on the 272 instead of the CDX2. It will improve your streaming and amplification as it works on both fronts.
I think the 202 is a sideways move and won’t bring big improvements and possibly none.
Worth trying the XPS on the 272 before you make any decisions anyhow!
I would strongly disagree with this, I think the 202 gets too much bad press around here. To my ears the 272 needs an XPS to compete with it.
Of course the 282 is better still, and it’s always more cost effective to make bigger jumps up the ladder less frequently, assuming one intends to keep climbing.
For that price inc Napsc I’d go for it I thought the 202/HC/200 a much underrated amp in my opinion a lot closer in SQ to the 282 than many believe and as you probably know the oldest, unserviced 282 you’re likely to find will still cost you double what you’ve been asked for that 202.
Live with the 202/200 for a while and then trade it for a 282 I’d also trade in that 272 for an NDX even the MK1 would be an upgrade over the 272.
If you have set your sights on the 282, it makes little sense to go with the 202 unless you don’t mind taking baby steps and want to try the 202 in your system. Having said that, I understand you are asking the question above hence leaving the 282 aside, it appears that only ChrisSU has compared both 202 and 272.
If the Hicap is a DR version, the 202 will sound great with it. Perhaps ask your friend if he can let you try the 202 in your system. At the price he is offering, it might be worthwhile to jump on it.
