I have problems finding the answer to my problem in the manual from NAIM:
I would like to select my vinyl source on the NAC 202 (CD input via external phono stage), be able to listen to it in my room (nac202+nap 200 DR) and simultaneously use an output from the NAC 202 to connect to the input of a streamer (bluesound). The output should be independant of volume and mute function on the nac 202 in the case I want to listen to music on my streaming system and not in the NAIM Room. (I would mute the sound completely on the naim system or turn it down by a lot)
Sould I use tape tape in/out ?
If the bluesound has an analog input (which seems odd for a streamer to have!), and if the NAC has a tape output (I think most Naim preamps have), then that’s what you want. It is possible that somewhere you will have to make a selection to make the tape output live.
If your streamer doesn’t have an analog input, then you’d need an ADC between the tape output and streamers digital input.
