hi
I have recently bought a remote control to get rid of the x no. remote controls. Got one problem though, I need an overview on function behind the buttons on the remote.
Ex:
“Vol up”= (some code)
hi
Ex:
If you mean you need the discrete RC5 codes that Naim use then best send Naim support an email as I they should have a document for this.
