Hi
I’m looking for a bit of help.
I have read the manual (wired I know) and if I understand it correctly, I think I can only two phono inputs to CD and Aux 2 inputs on the front panel.
Is that correct or am I missing something, or is there a workaround
I have two sets of phono cables I want to connect (turntable and TV) and I’d just like to connect them to Aux 1 and 2
Danny
That is correct - when enabled the RCA sockets are fixed to CD & Aux2 on the front panel.
If you wish to map any input to any button, you’ll need to upgrade to a 552
Neil.
Another reason to buy a 552 then
