Hi everyone ,
On output with every inputs (right channel only ) the signal is dark without high freq.
- with headphones all is ok
- fact. reset done
Iit’s a known issue ?
p.s. the din cable is ok
Hi everyone ,
Just to check the obvious, do you have speakers with two sets of terminals and links? If so, check the link hasn’t become disconnected or loose. This may sound like the voice of experience…l
This may not be a problem with the 272, to me sounds like it could be a speaker or less likely power amp issue. Have you tried swapping speaker leads to see if the problem changes the channel when you do so.
Well done ! Right speaker problem …internal crossover with a cold welding
Thank you guys
