Can I connect a grounding box to the grounding post of the NAC 282?
I believe the ground post is intended for a phono stage to be grounded to it
As above it’s usually used for TT grounding but as it’s just a signal ground connection you could connect a grounding box to it. Whether attaching a grounding box to your 282 is actually going to do anything useful is another question…
