Nac 52 problem
I may have damaged my Nac 52. I used the incorrect input[2b] instead of 2a when replacing a Stageline with a new Cyrus Signature Phono. I now have distortion thru both phono amps. My Rega P25/Hana MH sounded fine previously and the CD player and cassette deck work perfectly. I have powered everything down and will restart from scratch next week. Has anyone had a similar experience here?
Thanks!
No, I have no relevant experience, but as a fellow NAC52 user, I feel your pain!
I think this needs one of the Naim techs - not sure which one though.
@Richard.Dane
Probably needs @NeilS … :thinking:
It seems unusual that you would have a 2xRCA to 240° pin interconnect (for 2b), and I doubt that you would be able to insert a PSX-R cable into 2b on the NAC52.
A photo of your cable would help to analyse what might have happened…
Likewise I can’t see how you would have been able to connect to the powered AUX socket as it’s a 5pin 240 instead of a 180.
That was what I as thinking… after having located a Naim manual covering the 52…
Something is not right here.
I’d think one could “connect” it with enough… impetus.
Yes - definitely more info required on this one.
Neil.
@MKL1 Please keep us updated. Maybe there is no damage on 52.
Feel with you !
After replacing my Chord cable with a newer version, my Cyrus Executive Phono preamp is functional again. I will add the power supply tomorrow. Unfortunately replacing the Naim Snaic did not solve the distortion from my Stageline S. This unit is a few years old and may need service. Hopefully I did not knacker the powered input by trying to insert the wrong cable!
