Nac 52 PS
Will a Nac 52 PS work on all (every) Nac 52’s OR will it only work on older 52’s ???
Every, i think Paging @Richard.Dane
IIRC It will should work with any NAC52.
Be careful though if buying secondhand as some have been unofficially factory converted into a kind of bigger Hicap, usually for powering a Prefix (I had one - very good indeed, then passed it on to a friend). They won’t have a serial number though so should be easy to spot…
Then he turns up :wink:
