Hi all,
I have a NAC 552 preamp and would like to connect it to a non-Naim power amplifier that only has RCA inputs.
The NAC 552 provides output on a 4-pin 216° DIN connector, and I’m considering making a custom DIN-to-RCA interconnect.
Could someone please confirm:
- Which pins are left signal, right signal, and signal ground on the NAC 552 4-pin (216°) output?
- Is there anything unusual about the NAC 552 output wiring that I should be aware of when connecting to a standard single-ended RCA input power amp?
- Has anyone here successfully made or used such a cable?
Thanks in advance.
