Hi, can anyone tell me which Nac 72 input port the NDX streamer should be connected to? The entrance doors of my Nac 72 are cd, tuner. tape 1 and tape 2.
CD or Tuner will be fine.
I have an NDX 2 and I also asked the same question when I bought it in February. I was told…any. So I currently use the Tape 2. It works a treat.
Ok thank you very much.
If you have “CD” on a 72 then this is the later version with a DIN socket use this with the supplied lead from the NDX
