Hello.
I use a Denon DL-103R moving coil cartridge on an Linn LP12 with an Akurate configuration.
The DL-103R specifications are: output voltage 1.6 mV, output impedance 14 ohms.
The phono boards I mounted on the NAC 72 are of the NA323/5 type and I was wondering whether this is the optimum fit for the DL-103R. I would be grateful to anyone with an answer to this question.
Kind regards
Giuseppe
Many thanks for your advice. Will do.
Hello.
I can see a Music Room, is this what you meant?
