No cigar for you then
Fair enough, I misunderstood your actions.
Good luck.
Hi, I saw that you are Italian too. if @Richard.Dane puts us in touch in some way I can give you all the info you want. we have a small group of naim lovers in Italy. Iβm sure it might be useful to you .
[image]
[image]
As Suedkiz suggests, your sources are all falling behind the rest of your system.
You mention that the problem with the curent system is its not βclearβ so you might just need a better source.
Next time you are able to visit the Naim dealer ask to hear an NDX2/555PS or, if its in budget, a ND555/555PS. Of course, these will work very well with a Naim 252/300 set up.
