Sure are a lot of them…
Just wondering, for input from ND5XS2/nDAC, would there be a difference from one input to the other, or are they all essentially the same but with different labelling?
They are all essentially the same, other than the powered one of course.
But… 1, 2& 6 are wired differently than 3, 4 & 5?
Sonically they should all the same. If in doubt just try them. If you can’t hear a difference, then there is no difference.
