Can anyone confirm if a HiCap DR will power a NAC32 pre-amp (i.e. 4-pin DIN output? The Naim webpage offers this tantalising clue: “A compact power supply partner for almost all of our preamplifiers.”
Slightly odd pairing, yes, but this could be a useful stopgap move for me en route to a NAC282.
An older pre '93 HICAP could do, so long as the single rail (DIN4) supply has not been removed during a service).
Otherwise, if using a later HICAP with just a dual-rail supply (DIN5) then you would need a custom 5-4 SNAIC. Naim have not made many of these so very rare secondhand. You could probably order a new one though, but it would likely be built to order. Note that only one of the power rails would be used with this.
By default I don’t think so as your 32 is a single rail.
All CB and early Olives will do so though unless the have been updated to remove the largely redundant single rail socket 3 IIRC.
There may be a ‘cable workaround’ though. Experts would be needed here
