Has anyone on here use a cleaner like the one below?
I remember something similar that used a self adhesive roll type of thing that I feared would leave a sticky residue behind.
This one has a gel roller, similar to the gel stylus cleaners.
Even though I use an RCM, anti static sleeves and a nylon brush I still find a small amount of dust accumulates after a few plays. If anyone has used this or a similar roller I’d love to hear your views.
It was a great way to seemingly press any surface dust deeper into the grooves. And then a year or two later it lost all tackiness, in spite of careful cleaning exactly as recommended. I still have it, but for many years it has just languished in a big box of curious hifi accessories that i’ve wasted money on over the years.
If you just need something to quickly brush away any light surface dust to bits, then I would recommend the Hunt EDA or Goldring Super Exstatic brushes. None finer in my experience.
@SteveO
I also had one years ago and had a similar experience though in addition when at its stickiest it also seemed to increase static on the vinyl. Not an unqualified success. then…
