Having problems with the app crashing everytime I try to set the alarm time. Was working fine until after a system update. Tried re-installing the app still no go.
Any ideas?
Ta
Any ideas?
Ta
Welcome to the forum … is this the IOS or Android app you are using?
Android app
Sorry Aldo I have no experience with the Android.
I suggest you send a message to Naim support - they are very helpful.
Good luck with resolving the issue.
time to buy the Muso 2
More seriously, the ios app works better, from what i often read.
I would restart the router, then muso, then app. It should work.
