Hello, I need your help. In my alley the black insulation material is only slightly porous. What material can I use as a replacement without changing the sound?
Kind regards
Chris
Germany
Moin! That was discussed several times. Search the forum for more info. You can start here (from the old archived forum): Naim Audio Forum Archive
Ok, thanks for your help.
Kind regards
Chris
Hi. Were you able to source the foam replacements? One year ago or so they were available via the 'bay but not anymore, unfortunately… If there is some demand these foam replacements may become available again… Having Allaes myself I’m interested in the outcome of this so I’d appreciate some feedback. And since the foam is usable for SBLs (two per cabinet) and Allaes (three per cabinet) alike there’s even more possible demand, maybe… Thanks!
