Naim amps and sounds
I have a nac92 pre amp and a nap 90 power amp driving a linn axis with akito arm ,can i add anything to the amplification for better sound ??? I have kef 104 reference speakers !! Thanks
A serviced flat cap and bigger amp,
You could add a dedicated power supply to the pre-amp (Flatcap), but if it hasn’t been serviced within the last decade it may well do nothing at best and make the system sound poor at worst.
Beyond that, so long as the speakers aren’t a gross mismatch or just not to your taste at all*, it’s the usual upgrade heirarchy - Source - Pre-amp - Power amp - Speakers. So logically first look to the Axis/Akito/Mystery cart if you want to make sizeable, appreciable gains.
*I should say here that I have never personally been a fan of the KEF 104 Reference speakers and would likely change them out for one of any number of speakers of similar value were it my own system.
