I am wondering what the recommendations are for using Bluetooth headphones with a Naim amp.
I have 252. How would I hook up my BT headphones to that amp? What kit would I need and where would it plug in?
This would not be in any way a replacement for my normal audio experience- only occasional late night listening to not disturb the rest of the house. It’s not my intention to buy a headphone amp and dedicated headphone rig.
Amazon has a range of BT transmitter and receivers. You need an output from your Naim kit to plug in to the BT transmitter. I haven’t tried this but I would guess that the tape output would be suitable. You need a BT transmitter to send the Naim output to the headphones. Lots of Amazon BT dongles are for receiving only. There is a cheap receiver/transmitter on Amazon at the moment if you wanted to try out the concept before looking for something better or longer range.
Upon reading all the very helpful replies to my questions I think I’ll stick with loudspeakers and leave the BT headphones to my iPhone and podcasts.
It all sounds so complex - especially with the transmit/receive/DIN/3.5mm jack configurations and potential failure points. What a faff. I didn’t realise that something so simple would transform into something so complicated.
Hey ho - my 252/350 mono blocks continue to induce smiles through the Kudos 606s so I’ll live with that.
