I have the Naim app for my system, but I also use M Connect to stream FLAC through my iPhone to headphones or wireless Ruark speakers.
The M Connect can also control my Naim system in a simlar way to the Naim app.
My assumption/understanding is that the Naim app just provides an interface with my NAS held music.
So does M Connect do that or is it transfering/streaming music via my iphone to my Uniti? Thereby adding an additional bit of equipment into the chain.
There are 3 possibilities distinguished when you play a complete album and switch the device off (or sleep) part way through a track:
1 The album keeps playing: the controller app instructs the player to play a complete playlist (this is what the Naim App does). The player controls the playback, including the playist.
2 The current track keeps playing, but the next track doesn’t start (this is what HomeAV systems and many other generic UPnP/DLNA controllers do): the player plays each track individually after being instructed to do so by the controller app. The controller controls the playlist, the player controls the playback of each individual track.
3 The track stops playing immediately: in this case the stream is being sent to the player via the device.
There is a fourth possible scenario in which (on being tuned off) the device instructs the player to stop a track, but this is highly unlikely.
MConnectHD works by telling the Qobuz server to send a upnp stream to itself and then redirects to your NDX.
Convers digital, who make MConnectHD, told me that it sends the audio file as it is, unprocessed in that instance.
So either it should sound the same as the Naim app, or if there is a SQ difference it must be caused by the upnp stream changing what the NDX streaming board has to do to play that compared to a native Tidal or Spotify stream.
Generally I mainly listen to tracks on random play.
In the Naim App, once selected, it will play continuosly until I change input. Shutting the app completely or letting my iphone go to sleep does not stop play.
M Connect will play non stop even when phone goes to sleep, but will stop the stream if I fully close it down.
I guess that doesn’t help much.
In terms of SQ, can’t say these cloth ears notice any difference.
I do, but as I have M Connect to play all files to a wireless set of speakers and discovered it could do my Naim as well I thought I’d try that as well.
I read the forum with great interest and continue to learn so much from everyone. But one of the threads that appears every now and again is the ability to play Qobuz on the 272. I continue to be able to play hires files without problems using the mconnect app. Very occasionally I do get a track that buffers - but it is so occasional, I don’t worry about it. And when it does it ALWAYS coincides with the Wi-fi taking a hammering from the family. I know that is against most opinion which seems to suggest it’s due to the 272. Sorry if this is posted in the wrong thread but it seemed ok to mention it for others to try, should they wish…
