Naim App + Focal Naim App?
Perhaps a dim question but : -
I have NDX2 & QB running fine using Android tablet with App
I thought I would try downloading the App onto my mobile phone to see how I got on.
Google - Naim download - it comes up with Focal/Naim App and starts by telling me to point NDX2 remote…
I stopped there.
Can I download the Focal/Naim App onto my phone as well as having it running on my tablet?
I can’t find answer to that anywhere, and do not wish to spoil what already works
Yes. You can have it on as many devices as you like.
As already said yes you can,no problem. But be aware you can only use one at a time. Because the NDX can only handle one device connected when you want to control it with the app on your phone you have to stop the one on the tablet and vice versa. At least that’s how it works with my NDS. Guess it’s the same with the NDX2.
The second generation streamers such as the NDX2 handle multiple connections simultaneously.
Thx for clearing that up. Didn’t know that.
Thank you all for very quick replies - up & running !!!
What a forum !!! :stuck_out_tongue:
