Is there any way to make the album art and font larger on the NAIM app? Android btw.
I went through all the settings screens and couldn’t find anything and setting the basic Android to use larger icon and font didn’t seem to change the way the NAIM app presents things.
Just got a 10 inch tablet to use for control… well as a means to ease myself and SWMBO into the idea of stabbing at a screen rather than pushing a button. However the issue is I need glasses to read the text. So one option is to leave pair of reading glasses on the hifi rack or the other is to change the font size. Or
suppose an even bigger tablet!!
This is one of the reasons I’m not a fan of app control.
On the iOS app you can toggle between 3 different sizes of artwork, but the text remains the same size, with lots of empty space around it, which seems a bit daft to me.
Interestingly a failure to make a web site or app accessible is now a prosecutable offence. Sadly most people with access needs usually have bigger fish to fry.
They say you can adjust the font size (I mean the text underneath each album art) by changing the default system font size… nope that doesn’t work. Even set to largest there’s no change.
@solwisesteve, what happens if you gently touch the top line of album covers and slowly pull down on them, do you get more menu options above the top line now?
Like this, this is Tidal input, you can see search bar and view options in second image.
Yes as @ChrisSU said, unfortunately font size remains the same. But at least you have larger album covers. You probably know the album covers well, so now they bigger they should be easier to find.
A useful suggestion, I think, how about a built in screen saver for the app? I’ve tried the various other screen savers and, sometimes, the NAIM app will stall starting from the screen saver.
