My Naim app is failing to locate any of my three Naim streamers which are hooked up to my network. I have restarted the router and then turned on all of the streamers but still no joy. I don’t even have the option to locate anything - i just have a completely blank screen - the only icon that is responsive is the wheel in the top right hand corner which when clicked simply says settings but no more and i can do delve no further there either!
Anyone got any bright ideas? Should i delete the app and reinstall … i’m presuming that all of my playlists will be stored in Tidal and will transfer across?
Any advice welcome - i have of course done a search but cant readily find an answer to this
I had this same problem yesterday, unable to connect to either streamer. After a restart of my iPad and checking whether the app needed an update I discovered the iPad had connected to a different wifi network
