Hi folks, I know a few people on here are using the naim app on a mac using Big Sur, and I have the app loaded can stream radio, Tidal and change volume and inputs on my 272 and NDX.
But…it will not connect to a synology NAS. I just get the scrolling wheel.
I have deleted and reinstalled the app, no change.
NAS is still on DSM6.2.4, does it need to be updated for this to work?
I use the app successfully on an M1 MacBook with Synology NAS. It’s running Monterey rather than Big Sur, but I don’t think this should make a difference. I’m also on DSM 7, but again I doubt if that’s the issue, but could be wrong. I have MinimServer and Asset and the app finds both.
Do you have or could you download the VLC app on a tablet or your Mac and see if it can find the server on your NAS? That might help to pin down the problem.
Go to your Synology control panel.
Under the file services tab check if SMB is enabled.IIRC afp connection does not work anymore in Mac OS Big Sur or Monterey.
I know very little about Mac products (I’m Windows) but I normally have my Synology SMB disabled. The iPad & Android phone with the Naim apps will still open Asset UPnP & browse & play the NAS music share.
The reason why I have SMB disabled is to reduce the unwanted hibernation wake ups, I just enable SMB (tick the SMB box) when I need to write (upload or edit) to the music share.
I have this on my iPhone, and it shows the synology NAS with the name I have given it (Music Collection), and in any case both iPhone and iPad access and work NAS from the naim app.
Another piece of the jigsaw, is that I can select something to play from the NAS using iPhone or iPad, and it appears on the naim app on the Mac on the bottom info/volume bar, but the spinning wheel will continue and it will still not find the NAS!
Thanks, already tried that on the Mac and it didn’t work.
As the NAS can be seen by the streamer (and using remote select any album/track using the screen and buttons or remote) I’m assuming the NAS firewall setting DNLA/UPNP are set correctly.
