Hi suddenly got an issue with Naim App not displaying any tracks or sub folders under folders and nothing under playlist either. Works fine for other views. e.g. Artist/Album - does anyone have any ideas?
Synology 720+
Using Synology Audio Station as server
Bubble UPNP displays everything.
I’m not sure why you could do this before & what might have changed, but some observations.
The app only displays what’s sent to it, this is not an app problem
What UPnP are you using on the Synology ?
Audio Station purpose is to enable you to browse & play music from Synology over the Internet
I play Synology with only File Station installed & using Asset UPnP I can (if I select) to view & play Folder & sub folder views
Hi Mike,
I am thinking your questions relates to the UPNP server I use: it is identified as SynologyNAS720Plus so I am thinking it is Synology Audio Station? I can output from Synology Audio station directly to the Nova.
I have installed MinimServer2 and using this I can see all. The folder view is not such a loss but playlists I feel more.
As you say it is obviously not entirely an app problem but Bubble UPNP can see and display everything. Clearly something has broken - odd in that nothing, as far as I know, has been updated/changed. Might have to go down as one of life’s mysteries.
I think I am going to stay with MinimServer.
Unless you want to access & play from your NAS remotely over internet, you do not need Audio Station. I personally have never used it so cannot say if it can access Folder & Folder Sub Folder view/browse/play
To play from NAS you need an UPnP server, this will be something like the Synology ‘Media Server’ which is very basic, Minimserver is excellent, I prefer & use Asset UPnP.
Thanks Mike,
I have only used Audio Station to play anything when I have broken something and needed to test. I do use to create playlists so that I have something that sticks across all devices.
I only mentioned in case it was relevant - I can see now it is not.
I am going to stick with MinimServer as I kind of know it and have been very happy with the support received. I was not happy with support I received from Spoon in the past but I fully accept I may have been unlucky and certainly seem to be in the minority.
