I have a Core & NDS feeding a Linn power System. I knew I could not control volume via my Naim app on my iPad but I used to be able to pause and skip to either end of the track, no longer. Down loading a new version of the app made no difference
I can’t see any reason why this shouldn’t work. Are you using the Core as a UPnP server, or via SPDIF?
If UPnP, are you opening the NDS “room”? If you had inadvertently opened the Core instead on the app, I think you would find that the controls weren’t working.
Another Naim App question: My Core is hooked to ND555 both via S/PDIF and UPnP through eR. I have multiple Albums marked as Favourites on my App. Are they played via UPnP when I hit them on or is there a way to choose and dictate how these Favourites are to be played, S/PDIF ou UPnP?
