Started the long slow process of ripping and restoring my vinyl to my Uniti Star. All good thus far except the app/music store/server insists on re-ordering the tracks even if I number them. i.e. 1_Song Title.wav or even 01_Song Title.wav. It tends to put the last couple of tracks first and ignores the numbering system I’ve given the tracks.
OK, thank you for that but I don’t believe I’ve embedded any real metadata? I record the vinyl into Adobe Audition as a single wav. I then de-noise it and paint out/remove scratches. I put numbered markers in the still single wav file which correspond to the track numbers. I then hi-light each track portion of the wav and then “Save As”, I also give it a corresponding track number. If I load the file into iTunes it’s fine but frustratingly the Naim app is not playing ball and I just wondered if there was a work around? or I could just be being a numpty!
If it’s a WAV then you should use a metadata editor - something like dbpoweramp - to add some track numbering and titling metadata at least. This is what I do with my own digital recordings and they come up perfectly whatever the device I play them on.
On a related topic: having just migrated to the Naim app from Cambridge Audio’s StreamMagic app, one minor irritation is that when I ‘shuffle’ a Qobuz playlist, the displayed track order remains unchanged - it simply jumps back & forth - thus I have no idea of what is up next. In the StreamMagic app, shuffling a playlist also changed the track order (though this was using Tidal, my CXN V1 didn’t support Qobuz natively). Is this an app limitation, a Qobuz thing, or have I missed a setting somewhere?
