Hi this issue has just started, the skip to next track doesn’t work but the pause and go to previous track does
Very strange and annoying
Has anyone had the same issue ?
Mike
Mike
Which service?
Only suggestions…
Log out of music service and log back in.
Restart phone.
Try phone in landscape to eliminate possibility of damaged screen.
It’s the Naim app using tidal
Thanks will try
Yes but is it IOS or Android? They are different….
Ah……iOS
Don’t some
More checking and in an album the skip to next track works, it only doesn’t work when I choose the tracks tab see attached, I have tried changing the filtering but that doesn’t make any difference
Also couldn’t find where to log out of the app
