Thanks for sharing. What concerns did you raise with them, and have they said all your concerns are being addressed? Are you using apple or android device?
That was my response to ElMarko, who can do this because he has a Superuniti. The new streamers, and presumably also the Core, cannot do it, so unfortunately itβs not a solution for everybody.
I was trying to draw attention to the other thread as itβs where the OP set out what he was looking for and not draw attention to your specific post about something else. But the linking didnβt work quite as I expected.
The other thing I notice is that I canβt switch off the usb input which remains on the home screen. Not a big issue but Iβll never use it and a nice 3 choice upnp, radio, tidal would suit meβ¦unless Iβm missing something?
What app & what streamer do you have?
My iOS iPad - which is used mostly - & the Android phone, both have stop buttons & the USB (as well as all the inputs) can be turned off & on. This is with NDX with 4.7 f/w
Given that most of the changes in these updates are for the new streamers Iβm thinking itβs time to turn auto update off on my main Android device then update the app on the secondary to check my 172 still works OK.
