Today sees the release of minor updates to the Naim iOS and Android Apps β details below for both the iOS and Android versions. The updates are scheduled to go live shortly.
iOS v5.21
New features and updates
- Settings option to customise order of Sources layout on Home Screen
- VoiceOver on Rooms screen
- VoiceOver: announce top item as user scrolls
- New image handling library
Crash fixes
- Bluetooth pairing crashes
- Image rendering crash
- Memory allocation crashes
Bug fixes
- System automation selection issue
- Airplay Device setup error
- Qobuz and Tidal Favourites displaying when input disabled
- iPhone only - blank screen selecting βGo to albumβ from Now Playing
- Cannot enable Chromecast input via input settings menu
- Rooms screen not updating correctly during firmware update
Android v2.21
- Favourites Home Screen reflects last Favourites sort/filter
Crash fixes
- Home Screen crash when foregrounding
- TIDAL paging crash
- Older phones crashing trying to resize large background images
Bug fixes
- Core: Tidal/Qobuz are not filter options
- Now Playing bar glitching with scrolling text
- Setup Wizard incorrectly showing after factory reset
- Cannot remove tracks from play queue
- Default style should be plain black
- System Automation volume controls disappear
