Can you use the Naim app with an ND5 XS? It only gives the ND5 XS2 as an option on the Setup page.
TIA,
Tim
TIA,
Tim
Yes, you use it to control any Naim streamer. The options that appear on the screen are only the current models, but the old ones work too.
