I have installed the app on a new Android device but the playlists are different ftom my phone app.
Can’t see it in the Playstore, is it all new or the same app updated ?
IOS App it out as well.
Installed just seems a marginally new skin adding Focal for Naim sake.
That said checking it further annoyingly somewhere prior it reset my maximum volume, i prefer it at 100 at accustomed to that level, for a while system sound off, now solved.
My max volume is unchanged FWIW.
Just a side note as i think when I had some network issues I reset the app and streamer, back to 100 setting which is what I was used to and its all sounding sublime again.
