Naim app
Question…does the Naim app automatically update itself on release of new versions?
How can I tell which version I am currently running ?
Thanks …Steve w
That depends… If the settings in your phone/tablet are set to automatic updates, then yes.
I think you can see which version you’re using by clicking the “settings” in the app (the cog wheel).
Thanks :blush:
“App version”
5.16 is the latest.
