Naim Atom and 400 Ovator speakers
Hi All I have had this system for nearly a year and am very happy with it . I am waiting on some cables that Steve Huff recommended before I buy the naim ones which were recommended to me here . 3.5 m long minimum , Any recommendations for upgrades I can do , I stream everything and listen to radio , so no vinyl , cds, tapes , , Volume levels fine also . Many Thanks Hope your all well Regards Marc
No location and no detail of system, so I can’t offer an opinion
Martin
If you like the Ovators and intend to keep them, they are capable of showing what a much higher quality source and amp can deliver. I would avoid throwing money at tweaks, expensive cables and the like, and concentrate on the essentials. Upgrading the Atom to a Star or Nove, or moving to separates, will deliver real gains in all areas of performance.
Hi Martin In my front room in London hope that helps and system is in the heading . Fire away if anymore information required Thanks
Hi ChrisSU I defo dont want to move to separates as mainly use the radio and trying to get on with Qobuz . So streaming is the way I do everything. I think the speakers sound great and the Atom does everything I need but if I can get a better quality sound I would be very interested .
When I say separates I don’t mean multiple sources, just buying a streamer, preamp and power amp as separate boxes which is always the upgrade path in a Naim system, as it is with some other brands. The functionality is the same as it is with the Atom.
A Nova (or Nova PE) is as far as you can go if you want a single Naim box. The next step would be a 2 box system such as NDX2/Supernait or 222/250.
Hi ChrisSU Sorry it’s crystal clear now . I have been reading reviews and will have to have a think about which way to go , The Nova sounds like a simple answer but will have a look at your other suggestions , Much appreciated and Thanks for the Help Regards Marc
