Hi guys a totally immature question just wanted to know what should i do to connect a sub woofer to my setup which is Naim atom and KEF R3 i want to connect a sub woofer whats the recommended upgrade option i dont want to change the atom just want to add another Amp to power the sub . Please advise
If you get an active sub (and most subs are). Then you just connect with a lead from the pre-amp output (on the Atom) to the main input on the sub. Depending on the sub’s inputs, you might need to get a lead made up, but your dealer can advise on that
Welcome Sujith. I can confirm that works for a Uniti Star. Subwoofer must have it’s own amplification (i.e. active). Mine is a Cambridge Audio one with a straightforward RCA-to-RCA cable. For me the hardest part turned out to be realizing that the RCA cable was optimized to be connected in one direction only. That was my amateur experience
