Naim Atom Display Problem
Display is stuck on album art from previously played song. Tried reset options in app to no avail. Help!
That was a problem with the early firmware versions, a power off used to fix it on my Nova. If you’re running the latest firmware, it might be worth reporting the problem to Naim via the app so they know it hasn’t totally gone away.
You just need to power cycle the Atom. So turn it into standby, take the power plug out. Wait ten seconds, out the power on again and turn it on. Your display will be back to normal.
Best
Perfect. Thx for the suggestion.
